The Graphic converter is intended to convert BMP files into BASCOM Graphic Files (BGF) that can be used with Graphic LCD displays.
The following dialog box will be shown :
To load a picture click the Load button.
The picture may be 64 pixels high and 240 pixels width.
When the picture is larger it will be adjusted.
You can use your favorite graphic tool to create the bitmaps and use the Graphic converter to convert them into black and white images.
When you click the Save-button the picture will be converted into black and white.
Any non-white color will be converted into black.
The resulting file will have the BGF extension.
Press the Ok-button to return to the editor.
The picture can be shown with the ShowPic statement.
