The SE-812 from Sample Electronics is a programmer for the aduc812.
The programmer is well suited for in circuit programming.
Since it is a serial programmer that operates via the COM port, the programming is done with the terminal emulator. When you select the SE812 from the programmer options there will be an additional menu in the terminal emulator.
- Erase chip. This option will erase both the code flash and the EEPROM.
- Erase code flash. This option will erase only the code flash memory.
- Program chip. This will program the chip with the current program.
- Auto program. This will erase the chip and program the chip.
The programmer works only with version 2.00 of the boot loader.
