The SE511-SE516 can be used for the SE511 and SE516 programmers from Sample Electronics.
These programmers are serial programmers. They require a COM port.
When you launch the programmer, the current program will be loaded into the memory.
You can also use the LOAD button to load a program into the buffer.
Reset |
This button will reset the programmer and will determine the used chip. |
Load |
Load a binary or Intel HEX file into the buffer |
Save |
Save the current buffer to file |
Read |
Read the chip flash content |
Blank |
Test if a chip is blank |
Erase |
Erase (blank) a chip |
Write |
Write(program) the buffer into the chip |
Verify |
Verify if the buffer is the same as the chip content |
Lock Bits |
Write the selected lock bits |
