The 80517 and 80537 have more interrupts and priority is handled different compared to the 8051.
Enable interrupts:
ENABLE AD 'AD converter
ENABLE INT2|INT3|INT4|INT5|INT6 'external interrupt 2-6
ENABLE TIMER2EX 'timer2 external reload
ENABLE CTF 'compare timer interrupt
ENABLE SERIAL1 'serial1 interrupt
Disable interrupts:
DISABLE AD 'AD converter
DISABLE INT2|INT3|INT4|INT5|INT6 'external interrupt 2-6
DISABLE TIMER2EX 'timer2 external reload
DISABLE CTF 'compare timer interrupt
DISABLE SERIAL1 'serial1 interrupt
Selecting of priority:
PRIORITY SET|RESET source , level
level can be 0,1,2 or 3.(0=lowest,3=highest)
source can be :
INT0/ADC/SERIAL1
TIMER0/INT2
INT0/INT3
TIMER1/CTF/INT4
SERIAL/INT5
TIMER2/INT6
Note that only one of the TRIPLE-pairs must be selected.
PRIORITY SET INT4,3 'will set INT4 to the highest priority.
When two ints occur with the same priority the first source in the list will be handled first. So when both TIMER1 and INT4 have the same priority, TIMER1 will be serviced first.
Look at a datasheet for more details.
