The 80515, 80535, 80517 and 80537 have more interrupt sources and priority is handled different compared to the 8051.
Enable interrupts:
ENABLE AD 'AD converter
ENABLE INT2|INT3|INT4|INT5|INT6 'external interrupt 2-6
ENABLE TIMER2EX 'timer2 external reload
Disable interrupts:
DISABLE AD 'AD converter
DISABLE INT2|INT3|INT4|INT5|INT6 'external interrupt 2-6
DISABLE TIMER2EX 'timer2 external reload
Selecting of priority:
PRIORITY SET|RESET source , level
level can be 0,1,2 or 3.(0=lowest,3=highest)
The source can be :
INT0/ADC
TIMER0/INT2
INT0/INT3
TIMER1/INT4
SERIAL/INT5
TIMER2/INT6
Note that only one of the pairs must be selected.
PRIORITY SET INT4,3 'will set INT4 to the highest priority.
When two ints occur with the same priority the first source in the list will be handled first. So when both TIMER1 and INT4 have the same priority, TIMER1 will be serviced first. Look at a datasheet for more details.
