Specifies that serial output must be redirected.
$SERIALOUTPUT = label
label |
The name of the assembler routine that must be called when a character is sent to the serial buffer (SBUF). The character is placed into ACC. |
With the redirection of the PRINT and other serial output related commands, you can use your own routines.
This way you can use other devices as output devices.
See Also
$SERIALOUTPUT = MyOutput
'here goes your program
END
!myoutput:
;perform the needed actions here
mov sbuf, a ;serial output buffer (default)
ret
