This compiler directive will redirect all serial input to the LCD display instead of echoing to the serial port.
$SERIALINPUT2LCD
You can also write your own custom input or output driver with the $SERIALINPUT and $SERIALOUTPUT statements, but the $SERIALINPUT2LCD is handy when you use a LCD display.
$serialinput2lcd
Dim V As Byte
Cls
Input "Number " , V 'this will go to the LCD display
