With this option you can specify which files must be created.
Binary file |
This will generate a ROM-image of the program. Of course you can also store it in a flashrom. |
Debug file |
This option will generate a DBG-file. It is used by the simulator. When you don't use the simulator, you don't need to generate it. |
Hex file |
This is an Intel hex-file that is used by most programmers and monitor programs. |
Old Intel hex file |
This option will generate an old style Intel hex file and is used by the Elektor monitor. If you choose this option, you must unselect the Hex File option. |
Report file |
This file contains info about the program, such as the baudrate, used variables etc. |
Error file |
This file is generated when an error occurs. It holds the error descriptions. When there is no error, the file will not be created. |
