Start of inline assembly code block.
$ASM
Use $ASM together with $END ASM to insert a block of assembler code in your BASIC code.
You can also insert ASM code by preceding the line with the ! sign.
Dim c as Byte
$ASM
Mov r0,#{C} ;address of c
Mov a,#1
Mov @r0,a ;store 1 into var c
$END ASM
Print c
