The AT89S8252 ports have alternative functions.
The following table shows the alternative functions.
Port pin |
Alternate function |
P1.0 |
T2 external count input to timer.counter 2, clock out |
P1.1 |
T2EX timer/counter 2 capture/reload trigger and direction flag |
P1.4 |
/SS Slave port select input |
P1.5 |
MOSI Master data output, slave data input pin for SPI channel |
P1.6 |
MISO Master data input, slave data output pin for SPI channel |
P1.7 |
SCK Master clock output, slave clock input pin for SPI channel |
P3.0 |
RxD serial input port |
P3.1 |
TxD serial output port |
P3.2 |
/INT0 external interrupt 0 |
P3.3 |
/INT1 external interrupt 1 |
P3.4 |
T0 timer 0 external input |
P3.5 |
T1 timer 1 external input |
P3.6 |
/WR external data memory write strobe |
P3.7 |
/RD external data memory read strobe |
/ means active low
